Water pump rebuilding service.
:hello: 1986-2003 VOYAGER water pumps are very much like the ZL 900/1000 pump. The shaft seems to be longer and it appears that they take the 32 mm ceramic mechanical seal. I have six OEM ones in stock. Also the bearings most likely the same as the ZL9/10. 1986 to 2000 water pump part # 49044-1056. The 2001 to 2003 pump part # 49044-1082. I think one is black and the other one is silver. Both from KAWASAKI/PARTZILLA are $303 each. _____________________________________________________________________________________ 20230618_081854[1].jpg 20230618_081658[1].jpg 20230618_081759[1].jpg 20230618_082611[1].jpg 20230618_082801[1].jpg 20230618_082355[1].jpg 20230618_081503[1].jpg 20230618_082213[1].jpg 20230618_074236[1].jpg 20230618_074343[1].jpg 20230618_074415[1].jpg 20230618_074437[1].jpg 20230618_074707[1].jpg 20230618_074915[1].jpg 20230618_074934[1].jpg 20230618_074951[1].jpg 20230618_075011[1].jpg 20230618_075029[1].jpg 20230618_075230[1].jpg 20230618_075253[1].jpg
:hello: I did some more research on water pumps. The ZX 10/ZX 11/ZRX 1100/ZRX 1200R water pumps look very much like the ZL 9/10 pumps. Looks to me the pumps cover could be swapped out. Does anyone know someone who might have a ZX 10/ZX 11/ZRX 1100/ZRX 1200R water pump.20230619_113719[1].jpg 20230619_113602[1].jpg 20230619_113836[1].jpg 20230619_114227[1].jpg 20230619_114327[1].jpg 20230619_114356[1].jpg 20230619_114708[1].jpg 20230619_114809[1].jpg 20230619_114918[1].jpg 20230619_184510[1].jpg 20230619_184537[1].jpg 20230619_184600[1].jpg 20230619_184728[1].jpg 20230619_184757[1].jpg 20230619_184908[1].jpg
I will pull the 12R pump and check! Give me a couple days!
:hello: MARKUS: This is the PEAK antifreeze that I use in my ZLs. I get it at ACE Hardware. It cost $10 a gallon. I get it at cost for $5 a gal. 20230705_092355[1].jpg 20230705_092319[1].jpg
I bought Peak but it's not this label for sure. I've got an Ace close to me so I'll check there. Thanks!
:hello: MARKUS: I'm home now. I'll get to your water pumps Tuesday. Here is a copy of my receipt for the antifreeze from ACE Hardware. I got this type because it states made for older autos. Item # 8126708. ________________________________________________________________ 20230709_120054[1].jpg
:hello: My oldest Son bought the PEAK while I was in PA and used his B-day discount coupon but the regular price is $10 a gal and the owner of our ACE Hardware gives me $5.00 off. She also gives me at cost on all AMSOIL oils. For some reason AUTO ZONE want $21.95 for this type of PEAK.
:hello: MARKUS: I got your pumps apart. On all three the bearing that rests next to the ceramic mechanical seal is bad but the outter ones are good. Do you want me to replace both bearings in each pump. I'm also doing another ZL pump for a guy from IN that MADMAN knows. Worst pump I've ever seen. The shaft is even wore out by 2 mm. I'm doing all four at the same time. I'll keep his separated from yours. I have a doner pump to rebuild for the guy from IN.
Use your discretion on replacing the bearings. Are they not something you normally replace when rebuilding a pump? I know the Voyager pump felt very tight like the bearing was bad. Just make them reliable R.J., whatever that takes.
:hello:I just finished taking five water pumps apart. I have the shafts soaking in EVAPORUST. I'll leave them soak over night. I tried to upload four pics and only one went through. I sent ZL MARKY a PM weeks ago. His responce was I don't have time to look into anything. :banghead:. :pain10:. :cussing:. 20230712_130849[1].jpg 20230712_130919[1].jpg 20230712_130814[1].jpg 20230712_130740[1].jpg It takes about 3 minutes to up load a pic. One would not load at all.
:hello: I removed the water pumps shafts and propellers from the EVAPORUST. I polished them with SEMICROME polish. I'd post up pics but they won't load!!! :banghead:. :pain10:. :cussing:. Does this ZL MARKY character have a phone number!!!
That previous post was instantaneous
:hello: MARKUS: I have all three of your water pumps done. I'd post up pics but I can't. !!! :angryfire:. :banghead:. :pain10:. :cussing:. Why does no one else care!!! :angryfire:.:banghead:. :pain10:. :cussing:. :pistols:.
Looks like we are a rudderless ship here at ZL-OA for the time being. We need to get the leadership straightened out.
:hello: MARKUS: Yes we do. !!! :notworthy:. Did you get the pics that I sent to your phone. I have two phone numbers I'm not sure which one is your cell #.
